Hallo,
ich habe im Home Assistant dieses Addon installiert.
Da in der Dokumentation in HA steht, man braucht nur einen Account
und der MG 4 muß in diesem Account registriert sein,
hab ich es bei mir installiert.
Nach Eingabe meiner Daten steht dies im Fehlerprotokoll:
Code
2025-03-12 23:36:22,091 [ ERROR ] API call return code is not acceptable: 15033: {"code":15033,"message":"Sorry, the account has been locked, please try again tomorrow or you may reset password by clicking “forgot password”if you forget it."}. Headers: Headers({'date': 'Wed, 12 Mar 2025 22:36:22 GMT', 'content-type': 'application/x-www-form-urlencoded', 'connection': 'keep-alive', 'x-content-type-options': 'nosniff', 'x-xss-protection': '1; mode=block', 'cache-control': 'no-cache, no-store, max-age=0, must-revalidate', 'pragma': 'no-cache', 'expires': '0', 'x-frame-options': 'DENY', 'app-content-encrypted': '1', 'original-content-type': 'application/x-www-form-urlencoded', 'app-send-date': '1741818982079', 'app-verification-string': '476da6d5deeab999974f20d4f9682e3b178b7e1dff6762b2c862f442c896f46f', 'content-length': '165'}) - saic_ismart_client_ng.api.base
2025-03-12 23:36:22,091 [ ERROR ] Could not login to the SAIC API due to an error - root
Traceback (most recent call last):
File "/usr/src/app/handlers/relogin.py", line 44, in login
login_response_message = await self.__api.login()
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 51, in login
result = await self.execute_api_call(
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 87, in execute_api_call
raise e
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 76, in execute_api_call
return await self.__execute_api_call(
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 107, in __execute_api_call
return await self.__deserialize(req, response, out_type, allow_null_body)
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 200, in __deserialize
raise se
File "/usr/local/lib/python3.12/site-packages/saic_ismart_client_ng/api/base.py", line 183, in __deserialize
raise SaicApiException(error_message, return_code=return_code)
saic_ismart_client_ng.exceptions.SaicApiException: return code: 15033, message: Sorry, the account has been locked, please try again tomorrow or you may reset password by clicking “forgot password”if you forget it.
2025-03-12 23:36:22,092 [ ERROR ] MqttGateway crashed due to an Exception during startup - __main__
File "/usr/src/app/./mqtt_gateway.py", line 76, in run
await self.__relogin_handler.login()
File "/usr/src/app/handlers/relogin.py", line 48, in login
raise e
raise e
raise se
MQTT URI: tcp://192.168.178.120:1883
2025-03-12 23:36:22,116 [ ERROR ] Task was destroyed but it is pending!
task: <Task pending name='Task-1' coro=<Client._resend_qos_messages() running at /usr/local/lib/python3.12/site-packages/gmqtt/client.py:176>> - asyncio
sys:1: RuntimeWarning: coroutine 'Client._resend_qos_messages' was never awaited
Alles anzeigen
Was läuft da bei mir falsch?
